배기 매니폴더를 내려보자. D.I.Y. 자료실 -카마로ss동호회
배기 매니폴더를 내려보자.
김도영(SunShine)  |  조회수 :3897  |  2018-01-29 (15:40)
이것또한 혼자 DIY할수있는 수준의것은 아닌듯하지만, 양키들은 역시....ㅎㄷㄷ 하군요.
심지어 작업시간도 2시간쯤...
I'll get this started and add pictures and verbiage. I won't cover things like how to jack up your ride, disconnect the battery or have the spose provide you and the boys with beverage and food..
How hard: 1968 Big block Mustang is a 10 hard, a 1988 Fox Mustang is a 1 easy, a 1988 LS1 Camaro is 4: The 2016 SS is easier than a LS1, so it is a 3 on the hard scale.
Tools, this is the MOST important part, don't try it without the right tools.
24 V 3/8 driver impact driver or air ratchet (slightly bigger than a mouse chet)
1/4 drive: flex head ratchet, a long handle 1/4 drive flex head about 1 foot Kobalt makes a nice one), 13mm deep socket, short extension.
3/8 drive: breaker bar, flex head ratchet, 3 extensions, really short like 3/4 of an inch, short, kinda short like 3", don't say oh I can do this without these cause you aint. 13mm deep drive, a 13mm kinda deep may also help.
Assorted tools.
Drivers side:
Take off a few of the oil vapor lines easy and they get in the way and are easy to damage
Pull off the CAI (It is easy and leaves lots of room, not needed but I did it).
Pull plugs and wires, I had to twist the wire on the plug side A LOT before I could pull these off. I found using the correct 3/8 extension 3/4" which is really short one the most useful in pulling the out plugs. I had all three extensions at the ready and setup the right one by eyeball.
Take off top header shield with 1/4 inch I think there were 10mm. Only the three easy to get to bolts are needed, if they look hard to get to, you don't need to take them off to get the top shield off.
Header itself, break all bolts with 13mm and 3/8 flex head, once again it seemed the shortest extension is the most useful.
If you have an air ratchet luck you and just ratchet them off starting with the hardest to get to ones, the back one...
1/4 drive is your friend here as you can get a lot longer throw, GM used a thread locker on it so it will be a long haul and you don't want to be fooling around with a 3/8 ratchet. Don't tell anyone I just used me long Kobalt 1/4 driver on the passenger side to both break and take them off.
If this is done on a lift, It probably is better to crack the 4 collector bolts first. I'll just cut and paste the DYI of front cat removal here when I find it.
45 minutes. A lot longer if you don't have the couple extensions to do it right the first time.
Take off all three engine covers:
Passenger side:
Take off the coolant overflow:
Take off coil cover the top bracket to dipstick (all torx)
Take off bracket holding coil pack wire harness (thick), same bracket holds PS lines.
Cut the two zip ties that hold the wire harness to the PS pump, you will hate yourself if you want to save a couple of bucks and try to squeeze the ripple clips out.
Take off the front t wo coil pack wires
Take off the electric plug to the purge solenoid on top of the manifold
Take off spark plug wires
There is so much room I did not remove the plugs on this side!
Take off header shield three easy to get to bolts
Now the fun begins: move the wire harness and take the first front bolt off, I used my 1/4 inch long handle and a single deep socket, this is by the hardest to get to, and if you did not take the wire harness off good luck. Break all the rest of the bolts and take off starting with the back, the hardest one to get to and work forward.
If you have a lift take off the 4 bolts to downpipe / front cat, I could reach one with a slightly longer short socket and a whobble extension, if you don't have one it will be tight and you need a 15mm wrench.
Total time 35 minutes drivers side top
45 minutes passenger side top
35 minutes under the car for the front cats, use lots of lubricant and electric tools.
Install is reverse and I had NO issues..
일단 영어 그대로 퍼왔는데, 시간되는대로 해석을 하겠습니다. ㅎㅎ
  • 이상현(모터헤드) | 2018-01-29 16:11
영상 설명이 있어도 후덜덜할거같은데..ㅎㅎ
175 락커암, 푸쉬로드 조립  [1]
김도영(SunShine) I 2018-04-10 (10:03) I 조회: 3863
김도영(SunShine) 2018-04-10 (10:03) 3863
174 실린더 헤드 분해, 검사, 청소, 조립.  [1]
김도영(SunShine) I 2018-04-10 (10:01) I 조회: 3858
김도영(SunShine) 2018-04-10 (10:01) 3858
173 게이지 pod. 싱글 더블..  [2]
김도영(SunShine) I 2018-03-31 (20:14) I 조회: 4018
김도영(SunShine) 2018-03-31 (20:14) 4018
172 써모스텟 인스톨  [5]
김도영(SunShine) I 2018-03-28 (15:06) I 조회: 3893
김도영(SunShine) 2018-03-28 (15:06) 3893
171 공구한 레터링 다이했습니다~너무이쁘네요!!!  [10]
조용주(조단이아빠) I 2018-03-23 (23:32) I 조회: 3868
조용주(조단이아빠) 2018-03-23 (23:32) 3868
170 K&N 블랙호크 흡기 다이  [4]
김동현(부버버뵤료) I 2018-03-23 (02:40) I 조회: 3873
김동현(부버버뵤료) 2018-03-23 (02:40) 3873
169 리어 범퍼를 뜯고 디퓨져를 교환해봅시다.ㅎㅎ  [4]
김도영(SunShine) I 2018-03-13 (10:15) I 조회: 3866
김도영(SunShine) 2018-03-13 (10:15) 3866
168 도어트림을 뜯어봅시다.  [4]
김도영(SunShine) I 2018-03-07 (14:47) I 조회: 3872
김도영(SunShine) 2018-03-07 (14:47) 3872
167 에어컨 필터 교체 동영상이 있네요.  [3]
김호동(없어요) I 2018-02-23 (15:28) I 조회: 3887
김호동(없어요) 2018-02-23 (15:28) 3887
166 배기 매니폴더를 내려보자.  [1]
김도영(SunShine) I 2018-01-29 (15:40) I 조회: 3898
김도영(SunShine) 2018-01-29 (15:40) 3898
165 토크컨버터 교환.  [2]
김도영(SunShine) I 2018-01-29 (15:37) I 조회: 3874
김도영(SunShine) 2018-01-29 (15:37) 3874
164 미션을 내려보자~!   [1]
김도영(SunShine) I 2018-01-29 (15:36) I 조회: 3858
김도영(SunShine) 2018-01-29 (15:36) 3858
163 시트 스토퍼제거작업  [5]
김정민(질주본능) I 2018-01-17 (19:16) I 조회: 3855
김정민(질주본능) 2018-01-17 (19:16) 3855
162 카마로용(?) 다회용 휴지통  [11]
김태현(젊은오빠) I 2018-01-14 (21:34) I 조회: 3869
김태현(젊은오빠) 2018-01-14 (21:34) 3869
161 네비 17년 12월 업데이트 후 SW정보  [2]
정곤(수도산) I 2017-12-20 (07:41) I 조회: 3878
정곤(수도산) 2017-12-20 (07:41) 3878
160 카마로 블랙박스 상시   [2]
김정건(zoorich) I 2017-12-06 (23:40) I 조회: 3918
김정건(zoorich) 2017-12-06 (23:40) 3918
159 카마로 레터링 작업  [13]
박경락(대프리카) I 2017-11-17 (07:41) I 조회: 3906
박경락(대프리카) 2017-11-17 (07:41) 3906
158 알칸타라 씌우기ㅡ장착샷추가  [12]
문성진(폴쉐) I 2017-11-04 (10:22) I 조회: 3899
문성진(폴쉐) 2017-11-04 (10:22) 3899
157 키링이 왔어요~~  [6]
ShawnKim(MasiMaro) I 2017-11-03 (14:44) I 조회: 3914
ShawnKim(MasiMaro) 2017-11-03 (14:44) 3914
156 흡기필터를 교체해 보아요^^  [7]
김수덕(누리윙) I 2017-10-22 (16:38) I 조회: 3936
김수덕(누리윙) 2017-10-22 (16:38) 3936
