2019년형 보타이 (플로우타이 제거) D.I.Y. 자료실 -카마로ss동호회
김도영(SunShine)  |  조회수 :3940  |  2019-06-05 (10:20)
Tools:
• 10mm socket
• 13mm socket
• Long extensions
• T30H
• T15H
• Flathead Screw driver (or something to pry with)
• Mirror on a stick (with lights even better)
• Magnet (never know when you’ll drop something
1) Remove the following (1.jpg):
a. 4x 10mm bolts (yellow dots)
b. 6x T15H torx (red dots)
c. 2x T30H torx (purple dots)
d. Two rubber hood stops – count how many turns required so you can put them back at the same height (green dots)
Your shroud is now loose, however the hood latch is in the way for removal. Luckily it is very easy to remove.
2) Using your extensions and 13mm socket remove the hood latch bolts through the front grill. Once the bolts are out, just let it hang down. It might be a good idea to mark it off before you remove it so that you can put it back in exactly the same place
(3.jpg and 4.jpg)
3) Slide the radiator shroud towards the engine and slightly upwards, it should slide out with a bit of effort (5.jpg)
4) You can now access the back of the flowtie where it attaches to the bumper. Using a screwdriver or your pry tool and mirror gently pry each tab while pulling gently from the front, this was the most delicate and longest part of the job. There are 6 pins holding it in, however it was only the left and right sides I needed to work on, the top and bottom came out on their own. (7.jpg, 8.jpg)
5) Done. Now you can paint it and while you wait for it to dry, put everything back together. Since when you are done you can just press it back into the bumper. (9.jpg, 10.jpg)
영문 자료이긴하지만, 사진만 봐도 이해가 되는거라 ...ㅎㅎ
근데 문제는 이걸 제거한다고 해도 뒤에 형태는 남아있습니다.
  • 김철기(달구지) | 2019-06-05 10:52
걍 무광블랙으로 칠하는게..ㅎㅎ
  • 김주현(신록군) | 2019-06-05 13:20
빠다작업해야겠내용
  • 이상현(모터헤드) | 2019-06-05 17:48
제거한뒤 도색을 하거나 랩핑하고 다시 붙이는 용도겠지..?
235 [나눔] BMR 스테빌라이져 앤드 링크 Boots.  [3]
김도영(SunShine) I 2019-08-20 (13:52) I 조회: 3914
김도영(SunShine) 2019-08-20 (13:52) 3914
234 다이같지 않은다이  [5]
김주현(신록군) I 2019-08-20 (11:03) I 조회: 3918
김주현(신록군) 2019-08-20 (11:03) 3918
233 미션오일 교환하려는데 필터,가스켓 품번 좀 알려주세요!(미션오일추천도)  [2]
강준민(강준민) I 2019-08-04 (10:50) I 조회: 3916
강준민(강준민) 2019-08-04 (10:50) 3916
232 와이퍼 규격 Upgrade  [2]
최재훈(쵸이) I 2019-08-02 (18:16) I 조회: 3916
최재훈(쵸이) 2019-08-02 (18:16) 3916
231 쉐보레 마크  [1]
지주성(Asdfgg) I 2019-07-28 (00:51) I 조회: 3913
지주성(Asdfgg) 2019-07-28 (00:51) 3913
230 Oil Life 10% 미만일때 Alarm 뜨네요  [10]
최재훈(쵸이) I 2019-07-21 (03:25) I 조회: 3919
최재훈(쵸이) 2019-07-21 (03:25) 3919
229 프런트 범퍼와 후드의 단차 조정  [3]
김도영(SunShine) I 2019-07-15 (09:39) I 조회: 3926
김도영(SunShine) 2019-07-15 (09:39) 3926
228 도어 핸들키 실린더 커버 사용법.  [7]
김도영(SunShine) I 2019-07-03 (10:19) I 조회: 3903
김도영(SunShine) 2019-07-03 (10:19) 3903
227 데이라이트, 사이드 디플랙터의 깔끔한 배선을 원하신다면?~  [4]
김도영(SunShine) I 2019-06-13 (09:48) I 조회: 3925
김도영(SunShine) 2019-06-13 (09:48) 3925
226 2019년의 리어 미러가 부러우신분들을위한..  [7]
김도영(SunShine) I 2019-06-07 (11:00) I 조회: 3928
김도영(SunShine) 2019-06-07 (11:00) 3928
225 2019년형 보타이 (플로우타이 제거)  [3]
김도영(SunShine) I 2019-06-05 (10:20) I 조회: 3941
김도영(SunShine) 2019-06-05 (10:20) 3941
224 에바 크리닝 다이  [17]
김보겸(개미리더) I 2019-05-06 (19:41) I 조회: 4053
김보겸(개미리더) 2019-05-06 (19:41) 4053
223 가죽 핸들커버 씌우기  [16]
오승현(biondi) I 2019-04-17 (23:34) I 조회: 3913
오승현(biondi) 2019-04-17 (23:34) 3913
222 Foot Lamp 설치  [12]
최재훈(쵸이) I 2019-04-06 (18:25) I 조회: 3918
최재훈(쵸이) 2019-04-06 (18:25) 3918
221 다이는 아니고요 발판커버 장착했습니다  [9]
박주환(레드키스) I 2019-03-29 (12:33) I 조회: 3941
박주환(레드키스) 2019-03-29 (12:33) 3941
220 비오는 수요일엔 DIY를......  [17]
김태현(젊은오빠) I 2019-03-20 (18:21) I 조회: 3905
김태현(젊은오빠) 2019-03-20 (18:21) 3905
219 트렁크 조명등 추가  [10]
최재훈(쵸이) I 2019-03-19 (09:08) I 조회: 3924
최재훈(쵸이) 2019-03-19 (09:08) 3924
218 재사용 Cabin Air Filter 장착  [8]
최재훈(쵸이) I 2019-03-18 (11:59) I 조회: 3938
최재훈(쵸이) 2019-03-18 (11:59) 3938
217 엔진룸 내 서스펜션 마운트 캡 분실주의  [10]
최재훈(쵸이) I 2019-03-07 (09:33) I 조회: 3914
최재훈(쵸이) 2019-03-07 (09:33) 3914
216 풋등 관련 작업 사진  [6]
김호진(대수학) I 2019-03-04 (01:01) I 조회: 3909
김호진(대수학) 2019-03-04 (01:01) 3909
