엔진 경고등이떠서 확인해봤는데 |
근처 공업사에서는 스캔이 안된다해서 직접 odb로 봤습니다 ============1============== P069E Raw code: 069E ECU: 엔진 컨트롤 유닛 상태 확인된 OBDII: Fuel pump (FP) control module - MIL activation requested ============2============== P12E7 Raw code: 12E7 ECU: 7EB 상태 확인된 ============3============== P12EC Raw code: 12EC ECU: 7EB 상태 확인된 ============4============== P12F4 Raw code: 12F4 ECU: 7EB 상태 확인된 ============5============== P12F9 Raw code: 12F9 ECU: 7EB 상태 확인된 ============6============== P2535 Raw code: 2535 ECU: 7EB 상태 확인된 OBDII: Ignition switch, ON/start position - circuit high ============7============== P069E Raw code: 069E ECU: 엔진 컨트롤 유닛 상태 DTC supported by calibration, Current DTC, Test failed since DTC cleared, History DTC, Test not passed since current power up, Current DTC since power up OBDII: Fuel pump (FP) control module - MIL activation requested General Electrical Failures [0x00] ============8============== B3618 Raw code: B618 ECU: BCM 상태 DTC supported by calibration, Test failed since DTC cleared, History DTC, Current DTC since power up General Electrical Failures [0x00] 이렇게 나오는데.. 뭔말인진 모르겟고 동서울은 예약이 엄청 가득하고 머리가 아파오네요 |
