미쳐 알지 못했던 2016 CamaroSS 10가지 사실~!! 사용자 리뷰 -카마로ss동호회
이상현(모터헤드)  |  조회수 :5267  |  2016-08-18 (11:13)
2016 Camaro Facts – 10 Things You Didn’t Know!
Here’s a list of cool 2016 Chevrolet Camaro
facts! If you haven’t read up on it we recommend taking a quick look here
before you spoil some of the surprises below! Back!? Here we go!
CHECK OUT OUR YOUTUBE VIDEO ’10 FACTS YOU DIDN’T KNOW ABOUT THE 2016 CAMARO!’
2016 Chevrolet Camaro SS Ontario
2016 Chevrolet Camaro – 10 Things You Didn’t Know
1) It’s all new!
The 2016 Camaro is completely different than the vehicle it replaces. In fact, the only parts that carry over are the Chevrolet badge on the trunk and the ‘SS’ badge on Camaro SS models!
2) Dimensions
The 2016 Camaro is within two-inches of the vehicle it replaces in every direction. While it looks vastly lower and wider, the 2016 Camaro is actually a very similar size and shape! It all comes down to clever design.2016 Camaro SS Dimensions
3) Wind Tunnel Testing
The 2016 Camaro spent over 350 hours in the wind tunnel. Engineers used this time to optimize the design for cooling and aerodynamic efficiency.
4) Magnetic Ride Control
For the very first time Magnetic Ride Control (MRC) is an available option on the Camaro SS! The 2016 Camaro SS can be equipped with GM’s legendary suspension system, which can adjust more than 1000x per second. Previously, MRC was only available on Camaro ZL1!
READ OUR FULL STORY ON THE 2016 CAMARO RIGHT HERE!
5) Parking Brake
Sorry! No handbrake turns! The 2016 Camaro is equipped with an automatic parking brake, which means you’ll have to use even more power if you’re hoping to get it sideways on a track.
6) The Same, but Different
The 2016 Camaro SS features the LT1 V8 from the Corvette Stingray, however, it’s not entirely the same engine. In fact, 20% of the engine components are exclusive to the SS, including the new Tri-Y exhaust manifold!
2016 Camaro Tri-Y manifold
The Tri-Y exhaust manifold on the 2016 Camaro SS!
7) Cooling!
The base Camaro features one radiator, while the Camaro SS features another two radiators in the corners of the front grill, adjacent to the central radiator in the middle. It’s larger engine (455 hp V8) throws off more heat and more radiators help keep things cool!
WELDING
MIG welding vs. laser welding? The difference is clear!
8) Laser Welding
The 2016 Camaro features a laser welded roof! Typically, most vehicles typically feature a MIG-welded roof to keep costs down. However, it leaves an unsightly line. Now, the new Camaro looks even better than ever thanks its laser welded roof!
9) Interior Vents
An ingenious feature! In the 2016 Camaro the temperature is controlled using the ring around the vent! Simply turn it right for more heat, or left for more cool air. It’s simple, effective, and you’ll wonder why it took so long to invent!
10) Sounds Enhancement
Models equipped the 2.0L I4 engine and Bose Audio System feature engine sound enhancement, which amplifies the native sounds of the I4 turbo engine. The system can be switched off.
  • 이상현(모터헤드) | 2016-08-18 11:16
번역하지 않아서..당황하셨죠..?...네..저도 그렇습니다..ㅜㅜ
대략적인 의미만 파악했습니다.
  • 김도영(shinysun) | 2016-08-18 14:22
1. 전세대와는 다 틀림 벳지빼고
2. 사이즈가 전세대와 다 다름. 낮고 넓어보임
3. 터널 테스트를 통해 에어로다이나믹과 쿨링향상
4. 마그네틱라이드컨트롤!
5. 얼레 핸드브레잍크가읍네??
6. 스팅레이와 같은엔진이지만 매니폴더 형상의 개선
7. 라지에이터가 총 3개! 하나는 앤진오일냉각용
8. 레이져 용접
9. 실내 공조기가 특이함
10. Ss와는 관계없음 ㅎㅎ
  • 이상현(모터헤드) | 2016-08-18 14:28
ㄴ올ㅋ
  • 허현(아트) | 2016-08-18 18:34
오.. 잘봤습니다^^
  • 김경화(아리아) | 2016-08-19 09:33
좋은 자료 잘 보고 갑니다... 점점 더 매력에 빠져 드는듯... ^^;;
  • 한승환(환) | 2016-08-19 14:13
bk에서 보시던 분들을 여기서 뵙네요 ^^
상현이형님도 그렇고~
  • 이상현(모터헤드) | 2016-08-19 14:29
ㄴㅡ0ㅡ 야르~
  • 공석희(깨몽) | 2016-08-22 17:37
좋은 정보입니다 ^^]
  • 최혜식(ZamTing) | 2016-11-15 15:38
차 나오기 전엔 열심히 봤는데... 막상 차 나오니... 관심 부족! ㅋㅋ
  • 최민성(오르막깅) | 2023-05-04 17:53
잘보고갑니당 ㅎㅎ
21 풀악셀 가속영상이 떳네요^^  [10]
윤현석(블랙까롱이) I 2016-08-25 (10:28) I 조회: 5262
윤현석(블랙까롱이) 2016-08-25 (10:28) 5262
20 유저시승기  [5]
고재혁(악마의Z) I 2016-08-25 (00:29) I 조회: 5263
고재혁(악마의Z) 2016-08-25 (00:29) 5263
19 카마로 ss 연비주행  [9]
김도영(shinysun) I 2016-08-24 (20:57) I 조회: 5262
김도영(shinysun) 2016-08-24 (20:57) 5262
18 카레이서들의 시승기가 올라왔네요^^  [6]
윤현석(블랙까롱이) I 2016-08-24 (13:51) I 조회: 5269
윤현석(블랙까롱이) 2016-08-24 (13:51) 5269
17 ‘배기량’이라는 종교, 쉐보레 카마로 SS    [5]
이상현(모터헤드) I 2016-08-24 (13:07) I 조회: 5259
이상현(모터헤드) 2016-08-24 (13:07) 5259
16 2016년 카마로SS  시승현장  [17]
이상현(모터헤드) I 2016-08-23 (22:04) I 조회: 5267
이상현(모터헤드) 2016-08-23 (22:04) 5267
15 쉐보레 카마로 ss급가속  [8]
김도영(shinysun) I 2016-08-23 (12:10) I 조회: 5264
김도영(shinysun) 2016-08-23 (12:10) 5264
14 듀얼팁 순정머플러...  [7]
김도영(shinysun) I 2016-08-23 (11:29) I 조회: 5280
김도영(shinysun) 2016-08-23 (11:29) 5280
13 카마로ss시승기가 막올라오네요^  [8]
윤현석(블랙까롱이) I 2016-08-23 (10:18) I 조회: 5276
윤현석(블랙까롱이) 2016-08-23 (10:18) 5276
12 2016 카마로 SS의 라지에이터 구성  [5]
김도영(shinysun) I 2016-08-23 (10:08) I 조회: 5266
김도영(shinysun) 2016-08-23 (10:08) 5266
11 카마로 ss 6 Gen 은 얼마나 나갈까 궁금해서..  [3]
김도영(shinysun) I 2016-08-22 (21:19) I 조회: 5261
김도영(shinysun) 2016-08-22 (21:19) 5261
10 국내 카마로SS 시승 리뷰  [4]
이상현(모터헤드) I 2016-08-22 (00:34) I 조회: 5261
이상현(모터헤드) 2016-08-22 (00:34) 5261
9 ZL1 시동배기음 ㅎㄷㄷ  [11]
김도영(shinysun) I 2016-08-20 (14:28) I 조회: 5260
김도영(shinysun) 2016-08-20 (14:28) 5260
8 GM Apply Carplay in Camaro  [2]
김도영(shinysun) I 2016-08-20 (13:03) I 조회: 5262
김도영(shinysun) 2016-08-20 (13:03) 5262
7 GM Android Auto 소개  [1]
김도영(shinysun) I 2016-08-20 (13:00) I 조회: 5258
김도영(shinysun) 2016-08-20 (13:00) 5258
6 미쳐 알지 못했던 2016 CamaroSS 10가지 사실~!!  [10]
이상현(모터헤드) I 2016-08-18 (11:13) I 조회: 5268
이상현(모터헤드) 2016-08-18 (11:13) 5268
5 2016 카마로SS  드래그테스트 (수동vs오토)  [6]
이상현(모터헤드) I 2016-08-17 (08:58) I 조회: 5268
이상현(모터헤드) 2016-08-17 (08:58) 5268
4 따끈따끈한 카마로SS 수동과 오토비교 동영상!!  [3]
이상현(모터헤드) I 2016-08-17 (08:52) I 조회: 5261
이상현(모터헤드) 2016-08-17 (08:52) 5261
3 All New Camaro SS 소개영상-국내  [2]
이상현(모터헤드) I 2016-08-16 (14:12) I 조회: 5258
이상현(모터헤드) 2016-08-16 (14:12) 5258
2 2017 Camaro ZL1 발표  [3]
김도영(shinysun) I 2016-08-16 (09:39) I 조회: 5263
김도영(shinysun) 2016-08-16 (09:39) 5263
