콜벳 신형 C8 Stingray 공개. - 스팩 사용자 리뷰 -카마로ss동호회
김도영(SunShine)  |  조회수 :5253  |  2019-07-19 (13:14)
ENGINE
Type: LT2 6.2L V8 VVT with direct injection and Active Fuel Management (cylinder deactivation)
Bore & stroke (in / mm): 4.06 x 3.62 / 103.25 x 92
Block Material: A319-T7 cast aluminum with cast-in iron cylinder liners and nodular main bearing caps
Oiling System: Dry sump-type (7.5-qt. capacity); includes oil-spray piston cooling
Oil Type: Dexos 2 0W40 synthetic
Cylinder Head Material: 319-T7 cast aluminum
Combustion Chamber volume: 59cc
Compression Ratio: 11.5:1
Valvetrain: Overhead valve, two valves per cylinder; dual-equal variable valve timing.
Valve Size (in / mm): 2.13 / 54 hollow (intake) & 1.59 / 40.4 sodium filled (exhaust)
Fuel Delivery: Direct injection with Active Fuel Management: Max pressure: 2,175 psi (15 Mpa / 150 bar)
Firing Order: 1-8-7-2-6-5-4-3 (all cylinders); 1-7-6-4 (with deactivation)
Throttle body: 87mm single bore (electronic)
ECU: GM E99 (32-bit processing)
Horsepower (hp / kW @ rpm): 495 / 369 @ 6450 rpm (with performance exhaust)
Torque (lb.-ft./ Nm @ rpm): 470 / 637 @ 5150 rpm (with performance exhaust)
TRANSMISSION & AXLE
Type: M1L 8-speed dual clutch (DCT)
CHASSIS & SUSPENSION
Front Suspension: Short/long arm (SLA) double wishbone, forged aluminum upper and cast aluminum L-shape lower control arms; monotube shock absorbers (46mm /); Magnetic Selective Ride Control 4.0 available on Z51. Adjustable front lift with memory is available
Rear Suspension: Short/long arm (SLA) double wishbone, forged aluminum upper and cast aluminum L-shape lower control arms; direct-acting stabilizer bar; monotube shock absorbers (46mm); Magnetic Selective Ride Control 4.0 available with Z51
Steering Type: Bosch/ZF variable-ratio rack-and-pinion with electric power assist; includes Active Steer Stops with available Magnetic Ride Control 4.0
Steering ratio: 15.7:1
Turning Circle: 11.6 m (std.); 11.1 m (with FE4 Magnetic Ride Control)
Brake Type: Front and rear E-boost-assisted discs with Brembo four-piston/two-piece front calipers and four-piston/monobloc rear calipers. With Z51: Front and rear E-boost-assisted discs with Brembo four-piston monobloc caliper at front and rear
Brake Rotor Size (in / mm):
Front: 12.6 x 1.18 (321 x 30)
Front: 13.3 x 1.18 (345 x 30) – with Z51
Rear: 13.6 x 1.02 (339 x 26)
Rear: 13.8 x 1.06 (350 x 27) – with Z51
Wheel Size:
Front: 19-inch x 8.5-inch (w/5 x 120mm bolt pattern)
Rear: 20-inch x 11-inch (w/5 x 120mm bolt pattern)
Tire Type and Size:
Stingray: Michelin Pilot Sport ALS
Stingray with Z51: Michelin Pilot Sport 4S
Front: 245/35ZR19
Rear: 305/30ZR20
EXTERIOR DIMENSIONS
Wheelbase (in. / mm): 107.2 / 2722
Overall Length (in. / mm): 182.3/ 4630
Overall (in. / mm): 76.1 / 1934
Overall Height (in. / mm): 48.6 / 1234
Track (in. mm): (front) 64.9 / 1648 (rear) 62.4 / 1586
INTERIOR DIMENSIONS
Headroom (in. / mm): 37.9 / 962
Legroom (in. / mm): 42.8 / 1086
Shoulder Room (in. / mm): 54.4 / 1381
Hip Room (in. / mm): 52.0 / 1321
WEIGHTS & CAPACITIES
Dry Weight (lb. / kg): 3366 / 1530
Cargo Volume (cu. ft. / L): 12.6 / 356.8
사진등은
https://www.roadandtrack.com/new-cars/future-cars/a28437032/c8-mid-engine-corvette-stingray-2020-photos-specs/
  • 김경화(아리아) | 2019-07-19 14:47
495마력에 대략 65토크... 어마어마한 고출력이라 정말 조심해서 운전해야 할것 같군요,
외관도 멋지고........ 마로 다음으로 콜벳?? 시작 가격이 6만 달려라고 하니... 음...............!!!!!!!!!!!!!!!
  •  김철기(달구지) | 2019-07-19 17:22
       누님 범블비랑 비슷한 스펙 동일사양 엔진이에요 ㅎ
윗급메인 콜벳이 터보모델...
  •   김경화(아리아) | 2019-07-20 22:52
        헐.. 그러고 보니.... ㅋㅋㅋㅋㅋ
왜 저는 저순간 마로가 295마력이라고 생각했을까요?
늙은게야~ 눙물이....ㅠㅠ
  •   김경화(아리아) | 2019-07-19 17:32
        엄청 탐나네요.
국내 도입이 된다면 고민 많이 할것 같습니다~~ㅎㅎㅎ
  • 문석진(털보) | 2019-07-20 11:06
오... 덱소스2 라니.
다음 엔진오일은 0w40 덱소스2 규격 써봐야겠군요.
  • 김상필(서해) | 2019-07-20 12:49
너무너무 멋지지만 전 타기엔 현실적이나 실용적이나 뭘봐도 카마로가 제격인듯해요 더 낮아지면 .... 허허허허허허
  • 이준우(풍류랑이) | 2019-07-21 01:50
디자인이 정말 이쁘긴 하더라구요. ㅎㅎ. 실내도.
  • 김현우(김현우) | 2019-07-22 13:02
저렴하게 나오길..
  • 임자성(8기통) | 2019-08-06 22:05
성능 디자인 가격 뭐하나빠짐없는것같네요
  • 이찬혁(오리날다) | 2019-08-09 08:11
다음 목표!
  • 김민국(하리하리) | 2019-09-05 14:59
저도 돈 모아놓고 기다리고 있습니다. :)
  • 김병진(푸락셀) | 2019-10-08 10:20
정식 수입 된다는 말 있던데... 크...
281 슈퍼차져 성능향상 무상 업그레이드 감동 후기  [9]
박규호(프리스탈깡남) I 2019-12-23 (22:48) I 조회: 5254
박규호(프리스탈깡남) 2019-12-23 (22:48) 5254
280 구매 후 4일간 느낀점  [13]
문성호(엘레맨트) I 2019-12-17 (09:26) I 조회: 5260
문성호(엘레맨트) 2019-12-17 (09:26) 5260
279 로얄 코팅 후기 (공구)  [4]
이유하(알원엠이) I 2019-11-07 (18:45) I 조회: 5261
이유하(알원엠이) 2019-11-07 (18:45) 5261
278 Huron 트윈터보킷.  [8]
김도영(SunShine) I 2019-10-29 (10:44) I 조회: 6437
김도영(SunShine) 2019-10-29 (10:44) 6437
277 Lt1 vs lt4 head  [7]
김도영(SunShine) I 2019-10-27 (20:04) I 조회: 5259
김도영(SunShine) 2019-10-27 (20:04) 5259
276 ZL1 1LE 롤링레이스  [3]
김도영(SunShine) I 2019-10-24 (23:09) I 조회: 5261
김도영(SunShine) 2019-10-24 (23:09) 5261
275 레드마로님 표 프론트립 & 사이드스컷 장착 - 대구 JB 모터스  [9]
김정한(검마로) I 2019-10-20 (17:39) I 조회: 5246
김정한(검마로) 2019-10-20 (17:39) 5246
274 순정 배기는 과연 조용한가......  [8]
노정훈(칼엘) I 2019-10-01 (21:40) I 조회: 5258
노정훈(칼엘) 2019-10-01 (21:40) 5258
273 윈맥스 w3 패드 간단 사용후기  [6]
박대성(snfinder) I 2019-09-29 (22:17) I 조회: 5292
박대성(snfinder) 2019-09-29 (22:17) 5292
272 하드론 ZR 브레이크 패드 간단후기  [10]
김주영(대구인도) I 2019-09-15 (03:56) I 조회: 5275
김주영(대구인도) 2019-09-15 (03:56) 5275
271 휠 타이어 바꾼후 사용 후기-한타 S1 Evo3  [16]
김보겸(개미리더) I 2019-09-02 (15:08) I 조회: 5265
김보겸(개미리더) 2019-09-02 (15:08) 5265
270 한눈에 비교하는 맥너슨 2650 , 에델 2650, 위플 2900, 순정 lt5 2650  [2]
김도영(SunShine) I 2019-08-22 (10:41) I 조회: 5251
김도영(SunShine) 2019-08-22 (10:41) 5251
269 어후... NA 앤진마력 806HP ㅎㄷㄷ  [13]
김도영(SunShine) I 2019-08-20 (14:58) I 조회: 5263
김도영(SunShine) 2019-08-20 (14:58) 5263
268 ZO6 다이노콤   [15]
황성훈(우성랜드) I 2019-08-15 (00:32) I 조회: 5254
황성훈(우성랜드) 2019-08-15 (00:32) 5254
267 PP2 vs 1LE Car and Driver  [9]
김도영(SunShine) I 2019-07-23 (10:38) I 조회: 5258
김도영(SunShine) 2019-07-23 (10:38) 5258
266 콜벳 신형 C8 Stingray 공개. - 스팩  [12]
김도영(SunShine) I 2019-07-19 (13:14) I 조회: 5254
김도영(SunShine) 2019-07-19 (13:14) 5254
265 부러운 미국의 카마로 페스티발(사진)  [15]
김도영(SunShine) I 2019-07-18 (10:27) I 조회: 5247
김도영(SunShine) 2019-07-18 (10:27) 5247
264 콜벳 C8 실내유출이랍니다. ㅎㅎ  [8]
김도영(SunShine) I 2019-07-12 (11:12) I 조회: 5255
김도영(SunShine) 2019-07-12 (11:12) 5255
263 30초 카마로 광고  [10]
김도영(SunShine) I 2019-07-10 (14:28) I 조회: 5254
김도영(SunShine) 2019-07-10 (14:28) 5254
262 Stage 4 Cam , 시동 , 아이들 소리.  [6]
김도영(SunShine) I 2019-07-08 (15:48) I 조회: 5256
김도영(SunShine) 2019-07-08 (15:48) 5256
