Huron 트윈터보킷. 사용자 리뷰 -카마로ss동호회
Huron 트윈터보킷.
김도영(SunShine)  |  조회수 :6437  |  2019-10-29 (10:44)
Huron Speed is happy to introduce our new Twin Turbo system for the 2016+ Camaro SS and ZL1 platforms! After extensive design and testing we have finally released our twin turbo system to fit all of your needs from some small boost to your LT1 or 1250+ rwhp to your built engine setup! This setup also will fit all transmissions including the manual trans, A8 and even A10!
This system was certainly a difficult one which is why it took so long to release, however we have now confirmed all bases and tested the system up to 1258 rwhp on our ZL1 in collaboration with Vengeance Racing!
Here are some key features of the kit:
*Fits V-band inlet Turbochargers ranging from Billet 5858s up to Billet 6871s. This allows us to supply a very quick spooling set-up on a factory engine, up to 1250+ RWHP capability as shown on our shop ZL1 making 1258 rwhp along with a very easy installation
*Full 3″ Stainless Steel Downpipes are standard, sending the exhaust back into the tunnel for easy additional exhaust attachment to OEM or aftermarket axle-back systems eliminating any restriction areas.
*Full 3″ Intake piping off each turbo allows them to properly breath, along with routing over the factory skid plate keeping them out of the way of rain and debris to keep it daily driver friendly!
*Retains all OEM accessories in their OEM Locations
*Requires NO drilling/tapping for the oiling unless customer prefers.
*No heat issues like many top mount systems along with a very easy installation and very minimal relocation!
*Includes all necessary brackets and hardware
*Includes hose to retain PCV using the turbochargers inlet to retain suction
*Includes push lock hose and fittings for your boost reference hookups with CNC Billet Boost Log.
*OPTIONAL Bell Intercoolers large 6″ Air to Air intercooler which requires removal of the front bumper car, however provides unmatched cooling and airflow.
*OPTIONAL full customization to the kit including coating to the piping, anodizing to the intercooler, and anodozing/polishing/coating to the turbochargers. Standard will be a raw stainless hotside, with satin black cold side/intake piping and Black Series Intercooler.
Kit available in base form without Turbochargers, Wastegate, or BOV for $4499 plus shipping or COMPLETE with a Pair of Comp Oil-Less Turbochargers, Turbosmart Hyper-gate 45 Wastegates, Turbosmart Race-Port BOV for $7999 plus shipping.
Kit requires fueling upgrades based on your desired power goals.
ZL1 cars require removal of the OEM supercharger and to replace with an Intake Manifold
Kit is very straight forward to install and can all be done at home in your garage with basic hand tools!
Included Components:
*Full Hot-side including Stainless .120 wall exhaust manifolds with OEM plug and plug wire access, full stainless 3″ downpipes, mid-pipes, and connection pipes to the OEM axle-back location with all O2 bungs and factory hangers.
*Powder-coated Aluminum Cold-side tubing
*Powder-coated Aluminum 3″ intake tubes w/ PCV attachment
*All required silicone couplers and T-bolt clamps
*Large vertical flow Front Mount Intercooler w/ Bolt-on Brackets
*All required brackets and hardware
*Included all coolant hoses and fittings to run Comp Oil-Less turbochargers.
*Included CNC Billet Boost Log w/push-lock fittings and tubing to run all boost reference
*All required Grade-8 Hardware
*(2) Downpipe blankets for additional heat management
*50′ Roll of Heat Wrap
-Kit w/ Components also includes:
*Your choice in wheel size of Comp Oil-Less Billet Turbochargers, also customizable w/ anodizing
*(2) Turbosmart Hyper-gate 45 GenV Wastegates in your color choice of Black, Red, Blue, Purple
*Turbosmart Race-Port GenV BOV in your color choice of Black, Red, Blue, Purple
We sent our 2018 ZL1 A10 equipped car bone stock down to our friends at Vengenace Racing supplying them with our prototype kit fitted with a pair of Comp Billet 6871 Turbochargers and Turbosmart Components. Vengeance completed the installed with the addition of many other upgrades to show off the ability of the kit. We actually have more room in the system for power, but recently changed housings down to the .82's to bring the power in a little quicker. We landed at 1258 rwhp through the 3" air filters and full exhaust out the back on 25psi. Track results are pending as we quickly found the limits of the A10 transmission and are working on that now to head back to the track! The owner of Vengeance had nothing but great things to say about the Turbo system and its flawless performance which speaks volume coming from a shop as high caliber as Vengeance Racing!
셋 구성이 깔끔하네요
그래프도 ㅎㄷㄷㄷ
  • 이강혁(케서린아빠) | 2019-10-29 11:38
빨간색 인터쿨러가 맘에 드네~~ㅎㅎ
  • 김주현(신록군(일산)) | 2019-10-29 19:15
하부가 저리 아름다울수 있군요
  • 김철기(달구지) | 2019-10-29 20:04
터보 선구자의길 ㄱㄱ? buy it now?
  • 임자성(8기통) | 2019-10-30 07:05
무서워보입니다. ㅎㄷㄷ
  • 이제진(제이제이) | 2019-12-09 15:00
우와
  • 이제진(제이제이) | 2019-12-09 15:52
인터쿨러 멋짐 ~~
  • 김종환(에어레드) | 2020-01-08 07:20
마력이 쎄서 그런가요? 뒷 타이어 두께가 상당하네요 ㅎ
  • 강석효(moto) | 2020-03-04 18:37
트윈터보 평생의 로망이었어요!!
281 슈퍼차져 성능향상 무상 업그레이드 감동 후기  [9]
박규호(프리스탈깡남) I 2019-12-23 (22:48) I 조회: 5254
박규호(프리스탈깡남) 2019-12-23 (22:48) 5254
280 구매 후 4일간 느낀점  [13]
문성호(엘레맨트) I 2019-12-17 (09:26) I 조회: 5260
문성호(엘레맨트) 2019-12-17 (09:26) 5260
279 로얄 코팅 후기 (공구)  [4]
이유하(알원엠이) I 2019-11-07 (18:45) I 조회: 5261
이유하(알원엠이) 2019-11-07 (18:45) 5261
278 Huron 트윈터보킷.  [8]
김도영(SunShine) I 2019-10-29 (10:44) I 조회: 6438
김도영(SunShine) 2019-10-29 (10:44) 6438
277 Lt1 vs lt4 head  [7]
김도영(SunShine) I 2019-10-27 (20:04) I 조회: 5259
김도영(SunShine) 2019-10-27 (20:04) 5259
276 ZL1 1LE 롤링레이스  [3]
김도영(SunShine) I 2019-10-24 (23:09) I 조회: 5261
김도영(SunShine) 2019-10-24 (23:09) 5261
275 레드마로님 표 프론트립 & 사이드스컷 장착 - 대구 JB 모터스  [9]
김정한(검마로) I 2019-10-20 (17:39) I 조회: 5246
김정한(검마로) 2019-10-20 (17:39) 5246
274 순정 배기는 과연 조용한가......  [8]
노정훈(칼엘) I 2019-10-01 (21:40) I 조회: 5258
노정훈(칼엘) 2019-10-01 (21:40) 5258
273 윈맥스 w3 패드 간단 사용후기  [6]
박대성(snfinder) I 2019-09-29 (22:17) I 조회: 5292
박대성(snfinder) 2019-09-29 (22:17) 5292
272 하드론 ZR 브레이크 패드 간단후기  [10]
김주영(대구인도) I 2019-09-15 (03:56) I 조회: 5275
김주영(대구인도) 2019-09-15 (03:56) 5275
271 휠 타이어 바꾼후 사용 후기-한타 S1 Evo3  [16]
김보겸(개미리더) I 2019-09-02 (15:08) I 조회: 5265
김보겸(개미리더) 2019-09-02 (15:08) 5265
270 한눈에 비교하는 맥너슨 2650 , 에델 2650, 위플 2900, 순정 lt5 2650  [2]
김도영(SunShine) I 2019-08-22 (10:41) I 조회: 5251
김도영(SunShine) 2019-08-22 (10:41) 5251
269 어후... NA 앤진마력 806HP ㅎㄷㄷ  [13]
김도영(SunShine) I 2019-08-20 (14:58) I 조회: 5263
김도영(SunShine) 2019-08-20 (14:58) 5263
268 ZO6 다이노콤   [15]
황성훈(우성랜드) I 2019-08-15 (00:32) I 조회: 5254
황성훈(우성랜드) 2019-08-15 (00:32) 5254
267 PP2 vs 1LE Car and Driver  [9]
김도영(SunShine) I 2019-07-23 (10:38) I 조회: 5258
김도영(SunShine) 2019-07-23 (10:38) 5258
266 콜벳 신형 C8 Stingray 공개. - 스팩  [12]
김도영(SunShine) I 2019-07-19 (13:14) I 조회: 5254
김도영(SunShine) 2019-07-19 (13:14) 5254
265 부러운 미국의 카마로 페스티발(사진)  [15]
김도영(SunShine) I 2019-07-18 (10:27) I 조회: 5247
김도영(SunShine) 2019-07-18 (10:27) 5247
264 콜벳 C8 실내유출이랍니다. ㅎㅎ  [8]
김도영(SunShine) I 2019-07-12 (11:12) I 조회: 5255
김도영(SunShine) 2019-07-12 (11:12) 5255
263 30초 카마로 광고  [10]
김도영(SunShine) I 2019-07-10 (14:28) I 조회: 5254
김도영(SunShine) 2019-07-10 (14:28) 5254
262 Stage 4 Cam , 시동 , 아이들 소리.  [6]
김도영(SunShine) I 2019-07-08 (15:48) I 조회: 5256
김도영(SunShine) 2019-07-08 (15:48) 5256
