1000마력 슈퍼차져-Hennessey HPE1000 Upgrade 튜닝자료실 -카마로ss동호회
이상현(모터헤드)  |  조회수 :4869  |  2016-08-19 (09:12)
말그대로 1000 BHP(부하마력)을 뽑아낸 차져 킷인거 같은데 후덜덜 하군요.
http://www.hennesseyperformance.com
아래 항목들을 나중에 숩차 업그레이드시 참고할 만한 자료로 올려봅니다.
Power:
• 1008 bhp @ 6,500 rpm
• 918 lb-ft torque @ 4,000 rpm
Performance:
• 0-60 mph: 2.7 sec.
• 1/4 mile: 9.8 sec. @ 143 mph
• Top speed: 220+ mph
Includes:
• High-flow supercharger system.
• Extreme duty intercooler system.
• 416 CID Stroker motor.
• 4.0-inch Stroker crankshaft.
• Custom forged aluminum pistons with 11.5:1 compression ratio & steel wrist pins.
• 6.125-inch Billet steel H-beam connecting rods with ARP bolts.
• Balance, blueprint & assemble shortblock: fully de-bur block, line hone block with ARP main studs, deck block.
• Bore block on 3-axis CNC mill, hone block with torque plates, balance crankshaft, check bearing clearances.
• Assemble shortblock.
• CNC Ported Cylinder Heads ports- Competition valve job, extensive flow testing, chambers milled to desired cc.
• Lightweight hollow stem intake valves, exhaust valves.
• Extreme duty dual valve springs.
• Titanium retainers, machined locators & locks, GM valve seals.
• Chamber volumes measures & adjusted for compression.
• CNC work hand blended into valve job, spring pressures measured & adjusted.
• HPE hydraulic roller camshaft upgrade.
• Hydraulic lifter upgrade with extreme duty pushrods.
• 1.75 inch stainless steel long-tube headers.
• Stainless steel mid-pipe exhaust upgrade.
• High-flow catalytic converters.
• HPE engine management upgrade & chassis dyno calibration.
• Professional installation and all necessary gaskets & fluids.
• Chassis dyno testing.
You’ll receive a before & after dyno graph report showing power and torque measured at the rear wheels.
• Road testing (up to 100 miles).
• Hennessey exterior badge (rear).
• HPE1000 Powered by Hennessey badges (side & rear).
• Hennessey serial numbered plaque signed by John Hennessey (interior).
• Hennessey serial numbered plaque signed by the HPE technician (engine bay).
• Powered by Hennessey premium floor mats.
• Serial numbered Certificate of Authenticity personally signed by John Hennessey.
• Free lifetime membership in the official Hennessey Vehicle Registry (HVR).
• 1 Year / 12,000 mile limited warranty. Contact a Hennessey Performance sales associate for more details.
• Half of a tank of Shell V-Power 93 octane gasoline.
• Pennzoil Ultra Platinum synthetic oil & filter change.
아래 영상은 0~273Km/h 가속력 테스트 영상입니다
  • 이상현(모터헤드) | 2016-08-19 09:22
이것도 인스톨 해놓은거보면 엔진룸이 참 깔끔
  • 전창석(로뉘) | 2016-08-19 10:12
멋지다는 말밖에 안나오네요
  • 김도영(shinysun) | 2016-08-19 11:27
저건 앤진을뜯은거라 ㅎㅎ 전 이번엔 볼트온까지만 가기로
  • 노현민(2바부스트) | 2016-08-20 14:05
400미터가 9초대ㅠ
  • 아리스(아리스) | 2016-09-19 15:13
1천마력 ㄷㄷ.. 날개달면 날아가나요?
  • 임태웅(몬스터) | 2016-11-12 22:38
엔진터질듯한데영 ㅋㅋ
김도영(shinysun) I 2016-08-20 (12:25) I 조회: 4882
김도영(shinysun) 2016-08-20 (12:25) 4882
김도영(shinysun) I 2016-08-20 (12:13) I 조회: 4884
김도영(shinysun) 2016-08-20 (12:13) 4884
14 Borla 배기 for Camaro SS  [8]
김도영(shinysun) I 2016-08-19 (19:31) I 조회: 4873
김도영(shinysun) 2016-08-19 (19:31) 4873
13 1000마력 슈퍼차져-Hennessey HPE1000 Upgrade  [6]
이상현(모터헤드) I 2016-08-19 (09:12) I 조회: 4870
이상현(모터헤드) 2016-08-19 (09:12) 4870
12 Edelbrock Eforce Supercharger for Camaro SS 2016  [2]
김도영(shinysun) I 2016-08-19 (09:02) I 조회: 4885
김도영(shinysun) 2016-08-19 (09:02) 4885
11 카마로 SS에 들어가는 AT미션에 대해 알아봅시다.  [13]
김도영(shinysun) I 2016-08-18 (18:42) I 조회: 4880
김도영(shinysun) 2016-08-18 (18:42) 4880
10 2016 Camaro SS Single Turbo.  [8]
김도영(shinysun) I 2016-08-18 (17:39) I 조회: 4874
김도영(shinysun) 2016-08-18 (17:39) 4874
9 보그워너 2016 Camaro SS 트윈 터보  [3]
김도영(shinysun) I 2016-08-18 (17:34) I 조회: 4874
김도영(shinysun) 2016-08-18 (17:34) 4874
8 BMR 다운스프링  [4]
김도영(shinysun) I 2016-08-17 (22:52) I 조회: 4870
김도영(shinysun) 2016-08-17 (22:52) 4870
7 카마로의 엔진오일쿨러 ㅎㅎ  [5]
김도영(shinysun) I 2016-08-17 (18:36) I 조회: 4871
김도영(shinysun) 2016-08-17 (18:36) 4871
6 카마로 해외 쇼핑몰 소개  [5]
김도영(shinysun) I 2016-08-17 (16:36) I 조회: 4881
김도영(shinysun) 2016-08-17 (16:36) 4881
5 Roto-Fab Cold Air Intake System. 오픈흡기튜닝  [6]
김도영(shinysun) I 2016-08-17 (08:58) I 조회: 4870
김도영(shinysun) 2016-08-17 (08:58) 4870
4 가공형 스로틀 바디 장착 리뷰 및 다이노 결과  [3]
이상현(모터헤드) I 2016-08-16 (13:57) I 조회: 4871
이상현(모터헤드) 2016-08-16 (13:57) 4871
3 16 Camaro SS Procharger   [6]
김도영(shinysun) I 2016-08-16 (09:25) I 조회: 4875
김도영(shinysun) 2016-08-16 (09:25) 4875
2 Hooker Exhaust Camaro SS  [4]
이상현(모터헤드) I 2016-08-15 (17:58) I 조회: 4886
이상현(모터헤드) 2016-08-15 (17:58) 4886
1 튜닝자료실 이용 안내  [3]
운영자(V8매니아) I 2016-08-13 (18:57) I 조회: 4877
운영자(V8매니아) 2016-08-13 (18:57) 4877
