타이어 트리트먼트 (트랙션 증대) 튜닝자료실 -카마로ss동호회
타이어 트리트먼트 (트랙션 증대)
김지원(Dimitri)  |  조회수 :4882  |  2017-09-05 (10:53)
https://pitstopusa.com/i-5069291-pj1-trackbite-1-gallon.html
Features & Benefits:
  • Household name among traction compounds
  • 30 year history of success and consistency
  • Confidence among competitors in the Brand and Product
  • Enhanced Safety
  • Heightened Competition
  • Performs Excellent Under High Track Temperatures
  • Used by Leading Tracks & Sanctioning Bodies
    Ideal Applications:
  • Drag Strips *
  • Paved Ovals
  • https://www.amazon.com/Formula-V-Tire-Traction-Treatment/dp/B003FUY4BI
    Formula V Tire Traction Treatment
  • Will increase life of tires
  • Replenishes ingredients lost to heat cycles
  • Allows more heat cycles than otherwise possible
  • Keeps tires fresh and increases racing speed on ALL surfaces
  • Will NOT wash off
  • https://www.summitracing.com/int/parts/rci-6000x/overview/
    Racers! Now you can reduce your lap times between 2-5 tenths with TNT tire treatments from RCI. Just apply the coating before you hit the oval for increased traction and up to 50 percent longer tread life. TNT products work on both asphalt and dirt tracks, and are especially effective for kart racers and quick short heats. Depending on which Racer's Choice formula you select, the tire treatment will produce instant results, evaporating between 50 and 200 laps.
    미국애들이 드래그 하믄서 스프레이체인, 송진 부터 이런 전용 애프터마켓 제품까지 별걸 다 바르더라구요.
    젤 위에 제품이 그래도 젤 알려진 제품입니다.
    타이푼님께서 링크 주신 닥터페퍼 드레싱 ㅎㅎㅎ
    포럼 보면이것저것 섞어서 조합 하고 , 레시피 공유하는 애들도 있고.. 역시 양덕들은 무섭습니다.
    http://storefarm.naver.com/camelmart/products/120116587?NaPm=ct%3Dj77awjmo%7Cci%3D0yS0002qk-TnZo20qeNt%7Ctr%3Dpla%7Chk%3Da32f877d2a41a893e57c90d86146d7cb48c73dba
    • 김도영(SunShine) | 2017-09-05 11:53
    담은 이거닷 ㅋㅋ
    •  김지원(Dimitri) | 2017-09-05 16:58
           담번엔 제대로 도전하신다면, 발전기. 대형송풍기. 드라이아이스팩. 기본 정비공구 쌔려 싣고 미케닉으로 서포트하겠습니다.ㅋㅋ
    •   김도영(SunShine) | 2017-09-05 17:06
            담엔 들어와서 지면 안되...
    •    김지원(Dimitri) | 2017-09-05 17:10
             하............ㅠ 그래서 출전 포기하고 미케닉 전향 합니다............
    • 진근배(질주본능) | 2017-09-05 12:17
    저거 보니 겨울에 스노체인 개념으로 뿌리던 스프레이 생각나네요.
    •  김지원(Dimitri) | 2017-09-05 16:59
           넵 ㅎㅎ 예전에 많이 뿌리고 해봤었는데 너무 많이 뿌려가지고 휀다 작살나고 지우느라 개고생
    딱히 체감은 없는데. 술먹으러 가면서 컨디션 사먹는거 같은... 그냥 마음의 안정이랄까요? ㅋㅋ
    • 이상현(모터헤드) | 2017-09-05 12:59
    ㅋㅋㅋ 앞바퀴 들리게 닥터페퍼 음료수 드레싱 이거임!!
    •  김지원(Dimitri) | 2017-09-05 17:00
           링크에 추가해 두었습니다 ㅋㅋㅋㅋ 한짝 주문해야하나요?
    • 김문중(김똥개) | 2017-09-05 21:50
    모두들 마롱이 없으면, 무슨 재미로 사실려고 ㅋㅋㅋㅋㅋ.
    • 김경화(아리아) | 2017-09-06 09:11
    마로용 콜라인가요? ㅎㅎㅎㅎ
    진짜 마로 없으면 무슨재미로 살까요? ㅋㅋㅋ
    • 임자성(8기통) | 2017-09-06 16:45
    트리트먼트요?? 제 머리에도 못하는걸 카마로에?? ㅋㅋ
    316 rpm 게이지 장착하신 분 계신가요?  [6]
    김대원(대원) I 2017-09-23 (22:06) I 조회: 4885
    김대원(대원) 2017-09-23 (22:06) 4885
    315 메니폴드 단열테이핑 작업  [14]
    민병길(부산마초) I 2017-09-22 (11:16) I 조회: 4885
    민병길(부산마초) 2017-09-22 (11:16) 4885
    314 LT4 순정 차저 장착후 다이노측정결과.--  [31]
    문성진(폴쉐) I 2017-09-17 (02:13) I 조회: 4878
    문성진(폴쉐) 2017-09-17 (02:13) 4878
    313 Rear Seat Delete Kit  [6]
    김지원(Dimitri) I 2017-09-15 (17:51) I 조회: 4893
    김지원(Dimitri) 2017-09-15 (17:51) 4893
    312 페로도2500vsAP레이싱  [9]
    김철기(달구지) I 2017-09-15 (15:31) I 조회: 4892
    김철기(달구지) 2017-09-15 (15:31) 4892
    311 저항값 순정케이블vs튜닝케이블  [5]
    김철기(달구지) I 2017-09-15 (11:16) I 조회: 4895
    김철기(달구지) 2017-09-15 (11:16) 4895
    310 머플러 튜닝하신분들은 꼭 신경써주세요.   [20]
    김재민(감자) I 2017-09-14 (09:52) I 조회: 4896
    김재민(감자) 2017-09-14 (09:52) 4896
    309 카마로 순정휠에 장착할수 있는 최대치 사이즈가 어케 되나요?  [4]
    최영민(티무르) I 2017-09-13 (17:39) I 조회: 4885
    최영민(티무르) 2017-09-13 (17:39) 4885
    308 K&N오픈흡기 장착  [8]
    근희(빙뎅) I 2017-09-12 (23:11) I 조회: 4883
    근희(빙뎅) 2017-09-12 (23:11) 4883
    307 헤더튜닝&촉매 tip~  [18]
    김철기(달구지) I 2017-09-07 (23:13) I 조회: 4888
    김철기(달구지) 2017-09-07 (23:13) 4888
    306 85mm 풀리 업 다이노맵중  [17]
    김철기(달구지) I 2017-09-06 (18:27) I 조회: 4877
    김철기(달구지) 2017-09-06 (18:27) 4877
    305 타이어 트리트먼트 (트랙션 증대)  [11]
    김지원(Dimitri) I 2017-09-05 (10:53) I 조회: 4883
    김지원(Dimitri) 2017-09-05 (10:53) 4883
    304 메니작업 마무리중  [4]
    김철기(달구지) I 2017-09-04 (16:47) I 조회: 4878
    김철기(달구지) 2017-09-04 (16:47) 4878
    303 카마로 SS 트윈터보킷  [5]
    김도영(SunShine) I 2017-09-04 (14:06) I 조회: 4894
    김도영(SunShine) 2017-09-04 (14:06) 4894
    302 룩손에서나옹 차져용 스트럿바..  [11]
    김도영(SunShine) I 2017-08-26 (22:14) I 조회: 4878
    김도영(SunShine) 2017-08-26 (22:14) 4878
    301 LT4  순정차저 장착 완료.  [9]
    문성진(폴쉐) I 2017-08-26 (11:48) I 조회: 4887
    문성진(폴쉐) 2017-08-26 (11:48) 4887
    300 내년 봄 프로젝트....킬러칠러  [10]
    김도영(SunShine) I 2017-08-18 (20:38) I 조회: 4878
    김도영(SunShine) 2017-08-18 (20:38) 4878
    299 카마로 트윈터보 ㅎㅎ  [11]
    김도영(SunShine) I 2017-08-17 (10:29) I 조회: 4881
    김도영(SunShine) 2017-08-17 (10:29) 4881
    298 과급기에대한 좋은 영상이있어서..  [6]
    김도영(SunShine) I 2017-08-15 (10:57) I 조회: 4878
    김도영(SunShine) 2017-08-15 (10:57) 4878
    297 메탄킷 장착.   [11]
    김도영(SunShine) I 2017-08-11 (11:21) I 조회: 4892
    김도영(SunShine) 2017-08-11 (11:21) 4892
