4기통 모드 죽였을때, 나타나는 에러코드 튜닝자료실 -카마로ss동호회
김도영(SunShine)  |  조회수 :4868  |  2018-03-28 (13:04)
DTC P12E3: Cylinder Deactivation Exhaust Flow Valve Control Circuit Open
DTC P12E7: Cylinder Deactivation Exhaust Flow Valve Feedback Circuit Low Duty Cycle (Bank 1)
DTC P12E8: Cylinder Deactivation Exhaust Flow Valve Feedback Circuit High Duty Cycle (Bank 1)
DTC P12E9: Cylinder Deactivation Exhaust Flow Valve Open Position (Bank 1)
DTC P12EA: Cylinder Deactivation Exhaust Flow Valve Closed Position (Bank 1)
DTC P12EB: Cylinder Deactivation Exhaust Flow Valve Feedback Circuit Low Frequency (Bank 1)
DTC P12EC: Cylinder Deactivation Exhaust Flow Valve Feedback Circuit High Frequency (Bank 1)
DTC P12ED: Cylinder Deactivation Exhaust Flow Valve Feedback Circuit Incorrect Frequency (Bank 1)
DTC P12EF: Cylinder Deactivation Exhaust Flow Valve Stuck Closed (Bank 1)
DTC P12F0: Cylinder Deactivation Exhaust Flow Valve Stuck Open (Bank 1)
DTC P12F1: Cylinder Deactivation Exhaust Flow Valve Position Not Learned (Bank 1)
DTC P12F2: Cylinder Deactivation Exhaust Flow Valve Actuator Performance (Bank 1)
DTC P12F4: Cylinder Deactivation Exhaust Flow Valve Feedback Circuit Low Duty Cycle (Bank 2)
DTC P12F5: Cylinder Deactivation Exhaust Flow Valve Feedback Circuit High Duty Cycle (Bank 2)
DTC P12F6: Cylinder Deactivation Exhaust Flow Valve Open Position (Bank 2)
DTC P12F7: Cylinder Deactivation Exhaust Flow Valve Closed Position (Bank 2)
DTC P12F8: Cylinder Deactivation Exhaust Flow Valve Feedback Circuit Low Frequency (Bank 2)
DTC P12F9: Cylinder Deactivation Exhaust Flow Valve Feedback Circuit High Frequency (Bank 2)
DTC P12FA: Cylinder Deactivation Exhaust Flow Valve Feedback Circuit Incorrect Frequency (Bank 2)
DTC P12FC: Cylinder Deactivation Exhaust Flow Valve Stuck Closed (Bank 2)
DTC P12FD: Cylinder Deactivation Exhaust Flow Valve Stuck Open (Bank 2)
DTC P12FE: Cylinder Deactivation Exhaust Flow Valve Position Not Learned (Bank 2)
DTC P12FF: Cylinder Deactivation Exhaust Flow Valve Actuator Performance (Bank 2)
자 위의 코드를 No error report 로 해주시면 되것습니다. ㅎㅎㅎ
  • 김도영(SunShine) | 2018-03-28 13:08
아참 모드만 죽이면 상관없지만, AFM 모듈쪽을 하드위어적으로 제거하면 필요한거입니다.
  • 이상현(모터헤드) | 2018-03-28 14:06
맵핑스킬 하나씩 전수하는건가~??
  • 김경화(아리아) | 2018-03-28 18:32
아.. 이런 자료 보면 심쿵심쿵합니다~~!!
맵핑스킬 보유자~ 신기하고 대단하십니다.. ^^
  • 안상민(테란GG) | 2018-03-29 07:16
번역좀 해주시지!
ㅋㅋ.
  • 김철기(달구지) | 2018-03-30 14:19
4기톤 삭제..촉매보호모드만 죽여도 되는거 아녔음? DTC에서 이거 다 변경해야함? 에러코드는 안뜨든데..
  • pikon(pikon) | 2018-04-20 23:17
쉐보레 센터에서도 계속 못잡는 P12F0 코드 같은것도 아예 안뜨게 할수 있을려나요..
(고장 코드 뜨던 말던 전기능이 아주 정상적으로 작동 합니다만.. 예전 자유게시판에서도 글올린적은 있음. ㅎ)
VCM 이면 HP TUNER OBD2 쫌 전문적인 진단기 맞죠?
  •  김도영(SunShine) | 2018-04-20 23:23
       진단기가 아니고 맵핑장비라서요. 코드를 아예 에러안뜨게 삭제해버리는겁니다. ㅎㅎ 아마 되지않을까싶네요. 연료쪽 모듈은 1크래딧(49불)만 사용하면 됩니다.
  •   pikon(pikon) | 2018-04-22 00:08
        ㅠㅠ 제가 지방 살아서 당장은 못가지만 언젠가 도영님 튜닝하시는 샵 혹은 도영님 직접 찾아가서
저 빌어먹을 코드 지워 버리고 싶네요... 기회되면 연락드리겠습니다.(말은 이렇게 하지만 언제나 연락드리려나.. ㅠㅠ)
김만수(만수) I 2018-06-11 (18:05) I 조회: 4874
김만수(만수) 2018-06-11 (18:05) 4874
375 차져 배압의힘?  [9]
김철기(달구지) I 2018-06-05 (23:25) I 조회: 4874
김철기(달구지) 2018-06-05 (23:25) 4874
374 차져의 마무리?  [5]
김철기(달구지) I 2018-06-05 (23:04) I 조회: 4867
김철기(달구지) 2018-06-05 (23:04) 4867
민새이(엠투모터스) I 2018-06-04 (11:30) I 조회: 4877
민새이(엠투모터스) 2018-06-04 (11:30) 4877
김도영(SunShine) I 2018-06-04 (09:30) I 조회: 4871
김도영(SunShine) 2018-06-04 (09:30) 4871
371 위플차져 풀리, 베어링이슈..  [7]
김도영(SunShine) I 2018-06-02 (18:55) I 조회: 4870
김도영(SunShine) 2018-06-02 (18:55) 4870
민새이(엠투모터스) I 2018-05-29 (18:27) I 조회: 4870
민새이(엠투모터스) 2018-05-29 (18:27) 4870
369 에델블럭 2650차져킷 출시  [4]
김철기(달구지) I 2018-05-19 (19:42) I 조회: 4879
김철기(달구지) 2018-05-19 (19:42) 4879
368 메탄킷 인젝터 노즐의 선택..  [5]
김도영(SunShine) I 2018-05-15 (11:21) I 조회: 4868
김도영(SunShine) 2018-05-15 (11:21) 4868
김도영(SunShine) I 2018-05-09 (21:54) I 조회: 4873
김도영(SunShine) 2018-05-09 (21:54) 4873
366 차져를 다셨습니까?  [9]
김철기(달구지) I 2018-05-03 (14:51) I 조회: 4875
김철기(달구지) 2018-05-03 (14:51) 4875
김윤일(대구 N.EX.T) I 2018-04-25 (21:28) I 조회: 4877
김윤일(대구 N.EX.T) 2018-04-25 (21:28) 4877
364 인젝터와 연료라인 교환작업 메뉴얼  [2]
김도영(SunShine) I 2018-04-10 (10:07) I 조회: 4872
김도영(SunShine) 2018-04-10 (10:07) 4872
363 차져함 달려봤다는 동영상  [6]
김철기(달구지) I 2018-04-10 (09:01) I 조회: 4866
김철기(달구지) 2018-04-10 (09:01) 4866
임종철(이지) I 2018-04-05 (19:39) I 조회: 4887
임종철(이지) 2018-04-05 (19:39) 4887
361 앤진 연료에대한 확실한 솔루션...  [9]
김도영(SunShine) I 2018-03-29 (12:08) I 조회: 4865
김도영(SunShine) 2018-03-29 (12:08) 4865
김도영(SunShine) I 2018-03-28 (13:04) I 조회: 4869
김도영(SunShine) 2018-03-28 (13:04) 4869
김도영(SunShine) I 2018-03-27 (18:54) I 조회: 4869
김도영(SunShine) 2018-03-27 (18:54) 4869
김도영(SunShine) I 2018-03-09 (14:33) I 조회: 4873
김도영(SunShine) 2018-03-09 (14:33) 4873
357 AEM 메탄분사 필터.  [7]
김도영(SunShine) I 2018-02-28 (13:55) I 조회: 4872
김도영(SunShine) 2018-02-28 (13:55) 4872
