포팅 스로틀 소개. - 빠른 리스폰스 튜닝자료실 -카마로ss동호회
김도영(SunShine)  |  조회수 :5069  |  2019-07-10 (14:25)
- Throttle Lag
- Delayed response
- Car feeling heavy or not nimble
- Difficulty climbing hills at low/moderate throttle
- Uncertainty when passing other cars or unpredictable response at low/moderate throttle
- Stumble when shifting on manual transmissions
You name it, this has been my issue w/ my Corvette 7 since test driving at the dealership. I've tried a Throttle controller, AFM disabler, ECM Tuning, and arguably the three most talked about ported throttle bodies (PTB) out there. I have also combined some of the above w/ some success but still not enough. One just needs to hop into almost any other comparable car to feel they respond better.
After spending so much time/money, I decided to take it upon myself to find out, I also have all the equipment needed at work (measuring, testing, simulating, machining etc.)
Long story short; it is the throttle body. Between idle (~5 degree throttle) to ~30 deg throttle angle the amount of mass air flow (which is proportional to power) puts our cars at a weigh to power ratio similar to that of trucks and SUV’s, both in terms of absolute value and rate of change. Not to be confused w/ the weight to power ratio that is usually published, which is calculated at WOT, above 35 deg throttle angle our engines shine. It is on the part throttle range (idle to 30 deg) that the issue exists.
I’m not going to speculate on the reasons, but I can tell you that our throttle body p/n 12678223 or 12620263 is used in many GM vehicles and that such throttle response helps w/ fuel economy. That helps to keep parts cost low and meet EPA requirements for the fleet. However, I do not think one size fits all and that a high performance car needs to sacrifice performance for economy.
The throttle controller and the tune improve response by making the throttle plate move faster between the 5-30 deg range. Faster, but it still needs to go through a tortuous path for the air flow, and the manifold pressure doesn’t recover as fast. It is a transient process, and it is from the intake manifold where the pistons suck the air from. Notice that this is not true throttle response, it is just tricking the ECM into thinking you have pushed the accelerator pedal harder. The actual throttle response is the same, only physical changes to the throttle can make for a true throttle response.
The existing aftermarket ported throttle bodies also helped, they do change the throttle physically, but their effect only starts to take place at about 25 deg in what I thought was the best one of them. Definitely a step in the right direction, but I noticed they were not optimized and that more could be extracted from them, that is a throttle body that can increase the absolute value and rate of change of mass air flow right from idle and up to 35 degrees to achieve the same weight to power ratio (in that range) of similar high performance cars that feel nimble and fun to drive at part throttle.
Another long story short, I reversed engineered 10ea OEM throttle bodies, 3ea aftermarket ported throttle bodies, and a benchmark (competing car maker model) OEM throttle body. Optimized/modified the OEM throttle body to meet the benchmark throttle response as well as the goal stated above.
Our modified throttle bodies (MTB) are made (CNC machined) from a brand new OEM throttle body, flow and engine tested. Our design has been fully vetted by Corvette 7, Camaro 6, CTS-V owners, fully and openly tested by Corvette Forum members mainly. Driven in different conditions/modes for a few thousands of miles now at extreme temperatures and altitudes.
See pics below for more insight into what I’m talking about…and most importantly what do you think? All comments welcome.
Please visit us at : SolerEngineering.com
원본글입니다.
기존 친환경적인 스로틀에서 나타나는 단점들.. 스로틀 지연같은...것을 해결하기위해 포팅을 해서 테스트해봤는데
결과는 요렇다네요. 해외 반응도 나쁘지 않은듯?
  • 이강혁(케서린아빠) | 2019-07-10 14:36
어지럽다.............
어째든 좋타는 이야기 구만
  • 김보겸(개미리더) | 2019-07-10 18:09
중간의 메인샤프트를 깍아낸것과 상하단의 음각 구조가 핵심이군요. 버터플라이 밸브의 끝단 가공도 part throttle 에서 리스폰스 정확성을 높이는 핵심이고.
근데 내부 기어 백래쉬 줄이는건 어캐 했을라나? 기어를 새로 깍아서 하기엔 가격대비 대 공사인데...
  • 김지원(Dimitri) | 2019-07-11 09:07
와~~ 아이디어 좋네요. 개도가 시작되기 직전부터 contour 가 미리 공기 흐름을 유도하는군요. 확실히 효과가 있을것 같아요.
456 Rocker arm ratio 튜닝  [4]
김도영(SunShine) I 2019-08-27 (14:58) I 조회: 4879
김도영(SunShine) 2019-08-27 (14:58) 4879
455 BMR 스테빌라이져(Sway Bar) 브라켓 업그레이드.  [8]
김도영(SunShine) I 2019-08-20 (13:44) I 조회: 4878
김도영(SunShine) 2019-08-20 (13:44) 4878
454 고스트 캠소리를 만들어보자~  [5]
김도영(SunShine) I 2019-08-12 (10:53) I 조회: 4870
김도영(SunShine) 2019-08-12 (10:53) 4870
453 리프터는 존슨?  [4]
김철기(달구지) I 2019-08-05 (05:03) I 조회: 4886
김철기(달구지) 2019-08-05 (05:03) 4886
452 초대용량 저소음 머플러  [8]
김철기(달구지) I 2019-07-31 (17:22) I 조회: 4875
김철기(달구지) 2019-07-31 (17:22) 4875
451 Rocker Arm, Push Rod 그리고 Lifter 에 대해 알아보자.  [12]
김도영(SunShine) I 2019-07-26 (13:16) I 조회: 4875
김도영(SunShine) 2019-07-26 (13:16) 4875
450 LT4 + 45% 인잭터 소개  [8]
김도영(SunShine) I 2019-07-19 (10:50) I 조회: 4878
김도영(SunShine) 2019-07-19 (10:50) 4878
449 2인치 메니의 열과의 싸움과 간섭잡기  [9]
김철기(달구지) I 2019-07-18 (19:20) I 조회: 4876
김철기(달구지) 2019-07-18 (19:20) 4876
448 맥너슨 Z06 -2650 비교자료  [4]
김도영(SunShine) I 2019-07-16 (10:36) I 조회: 4878
김도영(SunShine) 2019-07-16 (10:36) 4878
447 LT4 vs 2300 vs 2650 쿨러크기 차이  [7]
김도영(SunShine) I 2019-07-15 (09:52) I 조회: 4871
김도영(SunShine) 2019-07-15 (09:52) 4871
446 FPCM 배선도입니다.  [1]
김도영(SunShine) I 2019-07-12 (15:07) I 조회: 4877
김도영(SunShine) 2019-07-12 (15:07) 4877
445 추후 캠작업등을 하실분들을 위한 Cam alignment  [3]
김도영(SunShine) I 2019-07-12 (11:23) I 조회: 4876
김도영(SunShine) 2019-07-12 (11:23) 4876
444 포팅 스로틀 소개. - 빠른 리스폰스  [3]
김도영(SunShine) I 2019-07-10 (14:25) I 조회: 5070
김도영(SunShine) 2019-07-10 (14:25) 5070
443 2650 Test 자료.  [3]
김도영(SunShine) I 2019-07-05 (14:46) I 조회: 4872
김도영(SunShine) 2019-07-05 (14:46) 4872
442 Eton TVS 2650 컴프맵입니다.  [8]
김도영(SunShine) I 2019-07-04 (11:57) I 조회: 4874
김도영(SunShine) 2019-07-04 (11:57) 4874
441 2650 Magnuson  [9]
김철기(달구지) I 2019-07-04 (04:57) I 조회: 4872
김철기(달구지) 2019-07-04 (04:57) 4872
440 카마로 십자가 엠블럼 문의요~!  [2]
박정찬(일산카마로) I 2019-06-26 (22:51) I 조회: 4874
박정찬(일산카마로) 2019-06-26 (22:51) 4874
439 1000마력 카마로를 만들어보자.  [6]
김도영(SunShine) I 2019-06-26 (11:15) I 조회: 4877
김도영(SunShine) 2019-06-26 (11:15) 4877
438 또 한대의 단조킷 차져 머신이 탄생한다고라...  [14]
김철기(달구지) I 2019-06-25 (03:46) I 조회: 4872
김철기(달구지) 2019-06-25 (03:46) 4872
437 카마로 ss 싱글터보   [6]
김도영(SunShine) I 2019-06-23 (20:30) I 조회: 4873
김도영(SunShine) 2019-06-23 (20:30) 4873
