LT4 + 45% 인잭터 소개 튜닝자료실 -카마로ss동호회
LT4 + 45% 인잭터 소개
김도영(SunShine)  |  조회수 :4877  |  2019-07-19 (10:50)
Our first 100% XDI manufactured and tested DI-Injectors are designed for the new GM LT series engines. With a 45% increase in flow over stock LT4 injectors, these supply the required fuel flow for high horsepower applications without the need for auxiliary fuel systems. These injectors are based on the original GM LT4 injector, which makes them a perfect drop in solution. Most of the ECU Injector characteristics stay the same.
Every Injector gets tested at 100bar and 200bar on OEM testing equipment at XDI. Every set gets flow matched to within ±0.5% at 100bar and 200bar fuel pressure !!!
Testing on several fully instrumented engines (8x O2, 8x EGT) done by Katech Inc. has shown unequaled results in terms of cylinder distribution, repeatability and stability at pressures up to 3000psi. Tuning changes required are minimal, offsets and current driver parameters stay the same. The injectors are E85 compatible and have so far been tested up to 1308bhp on engine dyno and 1067whp on roller dyno (Ignite E90).
Maximum Fuel Pressure is 220bar / 3200psi.
Straight E85, 1067whp GDI only !!!
no meth, no PFI, no extra ECUs, no wiring, full control, full OBD Diagnostics.
High horsepower GM Gen V V8 and V6 direct injection engines including LT5, LT4, LT1, L86, L83 and LV3
E85 conversions of GM Gen V V8 and V6 engines
2014+ C7 Corvette LT1
2015+ C7 Z06 Corvette LT4
2019 C7 ZR1 Corvette LT5
2016+ Camaro SS LT1
2017+ Camaro ZL1 LT4
2016+ CTS-V LT4
2014+ Silverado and Sierra with 4.3L LV3, 5.3L L83 and 6.2L L86 engines
2015+ Suburban, Tahoe, Yukon and Escalade with 5.3L L83 and 6.2L L86 engines
rated static flow rate: 25.6g/sec at 10MPa
– 67% more flow than production LT1/L86 injectors (15.3g/sec)
– 45% more flow than production LT4 injectors (17.7g/sec)
– E85 compatible
maximum pressure:
200bar / 2900psi (tested rock solid on engine and roller dyno)
240bar / 3500psi (under perfect conditions, no pressure pulsations)
이름하야 LT4 + 45% 더 인젝터...
기존 17.7g/sec 였던거가 25.6g 으로 상승이 가장 큰 팩터고요. HP 튜너지원하는 인젝터 데이터 제공
(맵핑에서 가장 중요한 요소 입니다. 아니면 삽질만 미친듯이 할수 있슴)
다이노상에서 메탄이고 아무것도 안걸고 휠 1000마력까지 뽑아낼수 있는용량을 넉넉히 제공한다 합니다.
이게 아시는분은 아시겠지만, 점점 올라갈수록 연료의 리미트가 결국 뽑을수 있는 한계점이 됩니다.
https://store.katechengines.com/xdi-high-flow-lt4lt5-injectors-45-p819.aspx
판매사이트는 여기, 오 가격이
3,999,92불...4,000불... 40만원? 아니네 0이 하나 더 붙었네요 ㅠ 세금까지하면 500만원...ㅎㄷㄷ
가격이 넘 사악하군요.
  • 이강혁(케서린아빠) | 2019-07-19 11:13
헐~~
미국생산 부품은 관세 없지않나 ??
  •  김도영(SunShine) | 2019-07-19 11:14
       부가세 내셔야죠. 10프로.
  •   이강혁(케서린아빠) | 2019-07-19 11:25
        아~~
그놈에 부가세
  • 천준호(튜브) | 2019-07-19 15:50
순정 레귤과 펌프에 달아도 효과 있나요?
  •  김도영(SunShine) | 2019-07-19 15:59
       전혀요. ㅎㅎ 역효과만나는수가..
  •   박준성(딴딴이) | 2019-07-30 04:10
        역관광 당하는 수가 있다는 거군요 ㅎㅎ
  • 김주현(신록군) | 2019-07-19 20:14
먼가 인젝터가 멋져보이는데 집에 데코용으로 놔둬두 무방할듯합니다 ㅋㅋㅋ 근데 비싸냉 ㅡㅡ
  • 김철기(달구지) | 2019-07-20 03:08
깔꼼하게 한방에 해결되는...
456 Rocker arm ratio 튜닝  [4]
김도영(SunShine) I 2019-08-27 (14:58) I 조회: 4878
김도영(SunShine) 2019-08-27 (14:58) 4878
455 BMR 스테빌라이져(Sway Bar) 브라켓 업그레이드.  [8]
김도영(SunShine) I 2019-08-20 (13:44) I 조회: 4878
김도영(SunShine) 2019-08-20 (13:44) 4878
454 고스트 캠소리를 만들어보자~  [5]
김도영(SunShine) I 2019-08-12 (10:53) I 조회: 4869
김도영(SunShine) 2019-08-12 (10:53) 4869
453 리프터는 존슨?  [4]
김철기(달구지) I 2019-08-05 (05:03) I 조회: 4885
김철기(달구지) 2019-08-05 (05:03) 4885
452 초대용량 저소음 머플러  [8]
김철기(달구지) I 2019-07-31 (17:22) I 조회: 4875
김철기(달구지) 2019-07-31 (17:22) 4875
451 Rocker Arm, Push Rod 그리고 Lifter 에 대해 알아보자.  [12]
김도영(SunShine) I 2019-07-26 (13:16) I 조회: 4875
김도영(SunShine) 2019-07-26 (13:16) 4875
450 LT4 + 45% 인잭터 소개  [8]
김도영(SunShine) I 2019-07-19 (10:50) I 조회: 4878
김도영(SunShine) 2019-07-19 (10:50) 4878
449 2인치 메니의 열과의 싸움과 간섭잡기  [9]
김철기(달구지) I 2019-07-18 (19:20) I 조회: 4876
김철기(달구지) 2019-07-18 (19:20) 4876
448 맥너슨 Z06 -2650 비교자료  [4]
김도영(SunShine) I 2019-07-16 (10:36) I 조회: 4878
김도영(SunShine) 2019-07-16 (10:36) 4878
447 LT4 vs 2300 vs 2650 쿨러크기 차이  [7]
김도영(SunShine) I 2019-07-15 (09:52) I 조회: 4870
김도영(SunShine) 2019-07-15 (09:52) 4870
446 FPCM 배선도입니다.  [1]
김도영(SunShine) I 2019-07-12 (15:07) I 조회: 4877
김도영(SunShine) 2019-07-12 (15:07) 4877
445 추후 캠작업등을 하실분들을 위한 Cam alignment  [3]
김도영(SunShine) I 2019-07-12 (11:23) I 조회: 4875
김도영(SunShine) 2019-07-12 (11:23) 4875
444 포팅 스로틀 소개. - 빠른 리스폰스  [3]
김도영(SunShine) I 2019-07-10 (14:25) I 조회: 5069
김도영(SunShine) 2019-07-10 (14:25) 5069
443 2650 Test 자료.  [3]
김도영(SunShine) I 2019-07-05 (14:46) I 조회: 4872
김도영(SunShine) 2019-07-05 (14:46) 4872
442 Eton TVS 2650 컴프맵입니다.  [8]
김도영(SunShine) I 2019-07-04 (11:57) I 조회: 4874
김도영(SunShine) 2019-07-04 (11:57) 4874
441 2650 Magnuson  [9]
김철기(달구지) I 2019-07-04 (04:57) I 조회: 4872
김철기(달구지) 2019-07-04 (04:57) 4872
440 카마로 십자가 엠블럼 문의요~!  [2]
박정찬(일산카마로) I 2019-06-26 (22:51) I 조회: 4874
박정찬(일산카마로) 2019-06-26 (22:51) 4874
439 1000마력 카마로를 만들어보자.  [6]
김도영(SunShine) I 2019-06-26 (11:15) I 조회: 4877
김도영(SunShine) 2019-06-26 (11:15) 4877
438 또 한대의 단조킷 차져 머신이 탄생한다고라...  [14]
김철기(달구지) I 2019-06-25 (03:46) I 조회: 4872
김철기(달구지) 2019-06-25 (03:46) 4872
437 카마로 ss 싱글터보   [6]
김도영(SunShine) I 2019-06-23 (20:30) I 조회: 4873
김도영(SunShine) 2019-06-23 (20:30) 4873
