XDI Pump System 소개 튜닝자료실 -카마로ss동호회
XDI Pump System 소개
김도영(SunShine)  |  조회수 :4876  |  2019-10-29 (10:28)
For 30% Over Injectors:
https://store.katechengines.com/kate...stem-p631.aspx
  • Static Flow Rate: 23g/sec
  • 50% more fuel flow than production LT1/L86 injectors
  • 30% more fuel flow than production LT4 injectors
  • E85 Compatible
  • 220bar / 3200psi Maximum Fuel Pressure
  • Supports up to 1200whp on race gas with our XFP 3600 fuel pump
For 65% Over Injectors:
https://store.katechengines.com/xdi-...s-65-p879.aspx
  • Static Flow Rate: 29.2g/sec
  • 91% more fuel flow than production LT1/L86 injectors
  • 65% more fuel flow than production LT4 injectors
  • E85 Compatible
  • 200bar / 2900psi Maximum Fuel Pressure
  • Supports up to 1500whp on race gas with our XFP 3600 fuel pump
For the XDI Pump System:
  • Additional 102% fuel flow to stock LT4 HPFP system
  • 242.7% more fuel flow compared to stock when paired with 40% over fuel lobe
  • 250bar / 3600psi Maximum Fuel Pressure
  • No meth, no port injection, and OEM-like driveability
For inquiries about becoming a dealer for XDI fuel systems, feel free to reach out to Katech or XDI.
  • 남윤형(너부리) | 2019-10-29 15:23
그렇군요ㅎㅎ
  • 김주현(신록군(일산)) | 2019-10-29 19:13
아름다운이야기군요
김도영(SunShine) I 2019-12-28 (12:02) I 조회: 4879
김도영(SunShine) 2019-12-28 (12:02) 4879
475 생순정 다이노 그래프입니다.   [2]
김도영(SunShine) I 2019-12-24 (11:22) I 조회: 4880
김도영(SunShine) 2019-12-24 (11:22) 4880
474 슈퍼차져 900 RWHP 달성.  [19]
김도영(SunShine) I 2019-12-09 (13:56) I 조회: 4873
김도영(SunShine) 2019-12-09 (13:56) 4873
473 우리 앤진에대한 맵핑의 기초부분...  [4]
김도영(SunShine) I 2019-12-09 (11:36) I 조회: 4872
김도영(SunShine) 2019-12-09 (11:36) 4872
472 헤드포팅 그래프에대한 고찰?  [1]
김도영(SunShine) I 2019-11-29 (10:45) I 조회: 4875
김도영(SunShine) 2019-11-29 (10:45) 4875
471 메탄/워터의 쿨링효과에 대해서.  [5]
김도영(SunShine) I 2019-11-22 (09:52) I 조회: 4876
김도영(SunShine) 2019-11-22 (09:52) 4876
470 하체 업그레이드 프로젝트 ㅎㅎ  [5]
김도영(SunShine) I 2019-11-20 (13:53) I 조회: 4871
김도영(SunShine) 2019-11-20 (13:53) 4871
469 새로나온 와일드 바디킷  [5]
한병욱(호두) I 2019-11-11 (22:45) I 조회: 4874
한병욱(호두) 2019-11-11 (22:45) 4874
468 LT1 하이켐 st2 520 휠마력!  [6]
김도영(SunShine) I 2019-10-30 (10:37) I 조회: 4880
김도영(SunShine) 2019-10-30 (10:37) 4880
467 XDI Pump System 소개  [2]
김도영(SunShine) I 2019-10-29 (10:28) I 조회: 4877
김도영(SunShine) 2019-10-29 (10:28) 4877
466 X파이프에 대해 알아보자.  [9]
김도영(SunShine) I 2019-10-27 (12:46) I 조회: 4872
김도영(SunShine) 2019-10-27 (12:46) 4872
465 속도에 비해 소리가쎈차?  [4]
김철기(달구지) I 2019-10-26 (22:30) I 조회: 4872
김철기(달구지) 2019-10-26 (22:30) 4872
김도영(SunShine) I 2019-10-24 (23:03) I 조회: 4870
김도영(SunShine) 2019-10-24 (23:03) 4870
463 Ring gap 조절의 정석 ㅎㅎ  [3]
김도영(SunShine) I 2019-10-23 (22:18) I 조회: 4868
김도영(SunShine) 2019-10-23 (22:18) 4868
462 후면 엠블럼  [5]
지주성(Asdfgg) I 2019-10-06 (22:59) I 조회: 4869
지주성(Asdfgg) 2019-10-06 (22:59) 4869
461 앤진 1000마력!  [9]
김도영(SunShine) I 2019-09-23 (00:04) I 조회: 4866
김도영(SunShine) 2019-09-23 (00:04) 4866
460 하다하다 끝물튜닝  [8]
김철기(달구지) I 2019-09-18 (01:14) I 조회: 4870
김철기(달구지) 2019-09-18 (01:14) 4870
김도영(SunShine) I 2019-09-11 (10:06) I 조회: 4871
김도영(SunShine) 2019-09-11 (10:06) 4871
458 제차 다이노 그래프입니다. 슈퍼차져.  [9]
김도영(SunShine) I 2019-09-10 (14:42) I 조회: 4871
김도영(SunShine) 2019-09-10 (14:42) 4871
김도영(SunShine) I 2019-09-05 (15:19) I 조회: 4869
김도영(SunShine) 2019-09-05 (15:19) 4869
