혹시나 Lt4 슈퍼차져를 올릴려면 필요한것들 튜닝자료실 -카마로ss동호회
김도영(SunShine)  |  조회수 :4893  |  2022-02-18 (20:35)
Mechanical Parts need to mount and run a PD blower:
Intake tube GM 22935828
Crank Pulley/Balancer GM 12671006 or 12687725
Crank Balancer Bolt GM 11547373
Tensioner GM 12663624
Pulley GM 12665845
Pulley Idler GM12642705
Pulley Idler GM12642707
ICT Billet Adapter LT1 Heads to LT4 intake ICT# 551590
GM Balancer w/ 3.50 blower puller 84.8" belt K408048
LT4 Valley cover AKA valve AFM lifter masnifold #12699793, 12675782, & 12674051 You can block off hole on the bottom of the blower
Easiest way to handle the intercooler system:
Intercooler pump with bracket Edelbrock number #51-4201
Intercooler Pump LT4/CTS-V GM #13597903
Intercooler water pump harness that Ts into the Evap #37-6619 or a lingenfelter L480340000 you will need to still to add a relay and wire the intercooler pump up
PLM Exchanger 350 for sock thickness and 395 for 2 inch plus thichness
3/4 Hose and preformed elbows by gates I leave this to you, you can setup
your I/C system how you want
ADM setup: sourced out: Parts used to mount the reservoir and mate to stock I/C hoses for and LT4
Gates 19839 premolded heater hose U will cut and route $10.00 Orileys
Gates 28479 premolded heater hose U will cut and route $10.00 Orileys
2 5/8 to 3/4 coupler $1.99
2 24mm constant tension spring hose clamps These are black look better $1.00 ea
6 26mm constant tension spring hose clamps $1.00
Edelbrock 51-7100 Tank – black reservoir like Magi or ADM $27.00
Edelbrock 51-7008 Tank lid - $13.00
Edelbrock 79-9177 Tank bracket - needs a bit of mods to attach to strut $35.00
SS reservoir install https://www.camaro6.com/forums/showthread.php?t=553155
Electrical System: T MAP MAF Harness..
Edelbrock # 37-1619 * for this map (0261230042) 2.5 bar
DSX harness dave can make harness if you tell which map you plan to use.
I will continue to updat..
$159.00 ZZP LT4 SC pulley 2.7 - to 2.8 depending on fuel mods
$350.00 12671006, 12687725, 12713718 LT4 Balancer (ATI ATI918856 & 916153 $475.00) for 100 more I would do this option
$238.00 12699793 LT4 valley cover or block of the PCV port
$54.00 12692675 Bracket for ZL1/CTS
$54.00 12663624 Belt tensioner with 8 rib Zl1
$43.00 12678515 8 rib Zl1 96mm pulley
$53.00 12678295 8 rib ZL1 77mm pulley
$55.00 12665845 8 rib smooth pulley ZL1
$23.00 12585673 LS3 front cover seal
2x Bolt, Hex Flange, M10 x 100mm
2x Bolt, Hex Flange, M8 x 55mm
3x Bolt, Hex Flange, M8 x 40mm
$219.00 551590 ICT Billet LT1 to LT4 Adapter
37-1605 Edelbrock water pump harness that's activated by the evap solenoid
37-6619 Edelbrock Baro harness for the MAF/TMAP
$395.00 PLM-HE-CH-CA-2017 PLM exchanger
$649.00 LPE L300227415 Bumper reservoir
$490.00 E2512A Stewart EMP intercooler pump (1 inch so you will need 1 in to 3/4 fitting to reduce. however there will be no 5/8 fittings on the car since like the zl1 so you will be way better off.
현재로써는 가장 저렴하게 슈퍼차져를 올릴수있는방법같습니다.
미국 사이트에서 lt4 차져는 대략 1500불정도에 거래가되는거같고
차져 단품만 업글하고 파는것이라 나머지 부품들이 필요한데
위와같습니다.
정 귀찮으면 한방에 모아서 파는 싸이트도 있습니다만 각각 구하는게 쌀듯
  • 김상필(서해) | 2022-02-19 00:09
암만 순정 챠져라고 해도 프로그램 튜닝등등은 할수 없겟지요???
순정 프로그램도 팔라나요??? 단순 부품만 교체 한다고 끝이 아닐듯한데요
  •  김도영(SunShine) | 2022-02-19 15:29
       맵은 따로 해야겠죠 ㅎㅎ
  • 김덕훈(밍구아빠) | 2022-02-19 20:47
제대로 된 비용 지불하고 샾에 맡기는 것이 가장 좋은 방법일지도 ㅎㅎ
576 공구하는 빅마우스 빠르게 장착해보았습니다.  [6]
김도영(SunShine) I 2022-05-10 (15:43) I 조회: 4892
김도영(SunShine) 2022-05-10 (15:43) 4892
575 순정 lt4/lt5 풀리시스템
김도영(SunShine) I 2022-02-20 (09:26) I 조회: 4883
김도영(SunShine) 2022-02-20 (09:26) 4883
574 혹시나 Lt4 슈퍼차져를 올릴려면 필요한것들  [3]
김도영(SunShine) I 2022-02-18 (20:35) I 조회: 4894
김도영(SunShine) 2022-02-18 (20:35) 4894
573 아래 사진의 차량 2650 + 캠 + 단조 + injection  [2]
김도영(SunShine) I 2022-02-11 (10:24) I 조회: 4891
김도영(SunShine) 2022-02-11 (10:24) 4891
572 슈퍼차져 노하우 최종 결정판?   [3]
김도영(SunShine) I 2022-02-09 (18:00) I 조회: 4877
김도영(SunShine) 2022-02-09 (18:00) 4877
571 2300 + 단조, st1캠
김도영(SunShine) I 2022-02-07 (22:41) I 조회: 4889
김도영(SunShine) 2022-02-07 (22:41) 4889
570 Lt2 인테이크용 90도 피팅
김도영(SunShine) I 2022-02-01 (22:28) I 조회: 4892
김도영(SunShine) 2022-02-01 (22:28) 4892
569 스로틀 사이즈 한눈에 비교 ㅎㅎ  [1]
김도영(SunShine) I 2022-01-18 (19:34) I 조회: 4873
김도영(SunShine) 2022-01-18 (19:34) 4873
568 Smooth boost 테스트  [3]
김도영(SunShine) I 2021-12-06 (20:00) I 조회: 4891
김도영(SunShine) 2021-12-06 (20:00) 4891
567 2300+단조+캠 후기  [5]
구본민(게토) I 2021-11-30 (15:35) I 조회: 4877
구본민(게토) 2021-11-30 (15:35) 4877
566 카마로 SS는 아니지만 ZL1 차져이신분들을 위한 LID
김도영(SunShine) I 2021-11-25 (17:33) I 조회: 4881
김도영(SunShine) 2021-11-25 (17:33) 4881
565 위플 슈퍼차져 3.0 Gen5
김도영(SunShine) I 2021-11-21 (15:43) I 조회: 4883
김도영(SunShine) 2021-11-21 (15:43) 4883
564 노메탄 캠 단조 2300차져차량 ㅎㅎ  [2]
김도영(SunShine) I 2021-11-17 (20:54) I 조회: 4898
김도영(SunShine) 2021-11-17 (20:54) 4898
563 부품이름알수있을까요??  [2]
정규태(3D그리) I 2021-11-17 (19:14) I 조회: 4880
정규태(3D그리) 2021-11-17 (19:14) 4880
562 역시 덕중에 덕은 양덕.  [1]
김도영(SunShine) I 2021-11-16 (10:23) I 조회: 4892
김도영(SunShine) 2021-11-16 (10:23) 4892
561 2300기본킷 에서 업글!!!  [2]
윤형중(TeeGee) I 2021-10-24 (12:04) I 조회: 4879
윤형중(TeeGee) 2021-10-24 (12:04) 4879
560 2300기본킷 후기   [10]
윤형중(TeeGee) I 2021-09-08 (00:49) I 조회: 4877
윤형중(TeeGee) 2021-09-08 (00:49) 4877
559   ┗[답글] 2300기본킷 후기   [2]
김도영(SunShine) I 2021-10-21 (21:37) I 조회: 4878
김도영(SunShine) 2021-10-21 (21:37) 4878
558 순정 서스펜션모드 슬렉터를 그대로 살리는 컨트롤러와 서스펜션  [1]
노정훈(칼엘) I 2021-08-15 (13:10) I 조회: 4878
노정훈(칼엘) 2021-08-15 (13:10) 4878
557 LT2 매니 후기 및 테스트 결과  [6]
구본민(게토) I 2021-07-25 (15:28) I 조회: 4877
구본민(게토) 2021-07-25 (15:28) 4877
